i need to use the count variable in crossCompany when i write it shoes error
container desiredCompanies = [‘CEU’, ‘KAR’,‘SS’];
Table cpy;
while select crossCompany count(fieldname): desiredCompanies cpy
How should i write?
Table cpy;
How should i write?
If you get an error, please always tell us what the error said and on which line it occurred.
Fortunately your two bugs are obvious to me, so I can answer it even with such an insufficient description.
This is the right syntax:
while select crossCompany: desiredCompanies count(fieldname) from cpy
As usually, you would find the answer in AX documentation:Select Statement Syntax. Please get used to consulting documentation, if you want to learn something.
