my System is: AX 2012 with the cumulative update 1 + 2 (in the installationguide of CRM Connector AX 2012 there is only a notice for the cumulative update 1 - pherhaps that is the problem, but i need the cumulative update 2)
You need to preform a code merge on the class declarations for the classes where the missing macros are listsed. For example, for the #CashDiscBaseDate error, you’ll need to merge syp and usr for the SalesSalesOrder_SaleTable class.
