CRM and AX Integration Test Setting Error.
Test settings failed:
The following exception occured while attempting to retrieve endpoints:
System.Net.WebException:The request failed with HTTP status 404:not found
A connection to the Microsoft Dynamics AX AIF Service could not be validated using the “”>tblax:8070/…/"URL.
The Event Log Message:
WebHost failed to process a request.
Sender Information: System.ServiceModel.Activation.HostedHttpRequestAsyncResult/59594809
Exception: System.Web.HttpException (0x80004005): The service ‘/MicrosoftDynamicsAXAif50/localendpointservice.svc’ does not exist. —> System.ServiceModel.EndpointNotFoundException: The service ‘/MicrosoftDynamicsAXAif50/localendpointservice.svc’ does not exist.
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath)
at System.ServiceModel.ServiceHostingEnvironment.EnsureServiceAvailableFast(String relativeVirtualPath)
at System.ServiceModel.Activation.HostedHttpRequestAsyncResult.HandleRequest()
at System.ServiceModel.Activation.HostedHttpRequestAsyncResult.BeginRequest()
at System.Runtime.AsyncResult.End[TAsyncResult](IAsyncResult result)
at System.ServiceModel.Activation.HostedHttpRequestAsyncResult.End(IAsyncResult result)
Process Name: w3wp
Process ID: 3576
Give a solution
Thanks in advance
Following this guide: msdn.microsoft.com/…/cc652581.aspx
You need to…
Go into AX > Basic Area > Setup > Application Integration Framework > Web Sites… and add a site with the path to your web service directory
Go into AX > Basic Area > Setup > Application Integration Framework > Services… Click Refresh… check LocalEndpointService… click generate
Open your web service directory and modify the web.config…
Remove httpModules section
Add a new bingind to <system.serviceModel>… “”
Update the binding and bindingConfig for each service behavior to wsHttpBinding and wsHttpWindowsAuthAif
