Critical problem: Cannot open Navision 5.0 database
Dear all,
Facing a critical problem at the time of opening Dynamics NAV 5.0 Database…!!
Screen msg…
PLz help to solve this issue.
Thanks!
Kindly check the HDD on which db stored
Is anybody tried to change the name of DB???
Regards
Amol
Yes this surely sounds like a bad disk!
My experience with these errors is that the best you can do now is to find you backup and restore to a different disk. Otherwise you will loose a lot of time, when you then find out that you cannot fix the database file.
Hi Subrata,
If your problem has been solved then please verify the solution that helped you or write the solution that solved your problem.
