Credit Limit Warning
Hi, Is there any way for some users to have no permissions to continue with an order when appears a Credit Limit Warning ? Thanks in advance
You need to define a User with no execute access for codeunit 312 : Cust-Check Cr. Limit
In this way the specified user when a Credit Limit warning is raised he system will try to execute the codeunit and if no permissions defined for that an exception message raises which stops the order proccesing.
