Credit limit pops up again and again after entering every line item.
Is there any way to stop the credit limit from popping up everytime I enter another line item on a Sales Order??
I don’t mind it popping up the first time but after every new line item I add it pops up again and again.
I want it to pop up once for an order then not pop up again.
Any solutions??
Thanks in advance,
Greg
Not without a modification that I am aware of. They really don’t want you to sell to someone over their limit [:)]
You’d have to keep up with whether is has already been shown, via a variable or field. Have to reset it every time you move to another record.
I see a call to Customer Credit Check in Sales Line Table under Function “Update Amounts”
“Update Amounts”
InitOutstandingAmount;
IF (CurrFieldNo <> 0) AND
(“Document Type” <= “Document Type”::Invoice) AND
((“Outstanding Amount” + “Shipped Not Invoiced”) > 0)
THEN
CustCheckCreditLimit.SalesLineCheck(Rec);
I guess you could also add a boolean to the header called “Bypass Credit Check”.
Then add to the If statement "AND NOT SalesHeader.“Bypass Credit Check” THEN
Let me play with it a little.
Thanks for all the replies.
Greg
It is “On” or “Off” at the line level. If you want to turn it off:
Menu “Sales and Marketing” → “Setup” → “Sales and Receivable Setup” → Dropdown menu “Credit Warnings”
As I stated, ON or OFF. It will pop for every line or not at all. It makes sense from a business perspective. If you are in a LIVE env. and you get that message all the time, it is a RED flag for finance people. You might want to revise your credit limit for that customer.
Notice the “StockOut Warning” underneath. If you are doing some testing/Dev, you might want to turn it off for that period. :slight_smile:
Hope this helps!
