Creating page in NAV2016 development using form xxxxx to create page xxxxx. After I save d page and compile it, I discovered "When the function is called, the minimum number of parameter should be used. for example: MyFunc(…,…,…)
ROUND(MyVar)
ROUND(MyVar,0.05)
your page has code which is calling a function with not all parameters.
when you compile the page, the pointer will take you the exact place where the function is called. you need to correct it.
hii
i think your form using some standard function of standard table in old version like nav 2009, if you upgrade this form in to page in 2016, this page have that function of standard table , that are not have enough parameter in 2016.
so first check your standard function of table in nav 2009 and compare with nav 2016 standard function of table.
