Creating new Dataports
I got a quick 10min. course on how to create a new dataport in object designer. I figure out everthing but how to make the new dataport export only. Can anyone help me?
If you look at the properties for a datport there is an Import property - simply set this to No. Remember, to see the dataport properties you must have a blank line selected - if you have a line with a dataitem on it you will just see the properties for that item. That should do it. [:)]
Thank you. You were right I was not on a blank line.
