Hi Friends,
I have some master data in excel sheet.I need to import to our ax -2012.What is the process need to follow? I need the complete steps to import the data and as well as tables I need to relate if at all required.
Krisheed
Hi Friends,
Krisheed
Dear Krisheed,
what are the data and what you want to upload.
there are some limitation where you cannot upload all thing is AX until and unless you make deep customization.
provide the info may be we can help you out.
Skype ID:- hacker_ng
Thanks Husain,
I have the information in an excel sheet and I need to import that data into ax.
Usually you need to know what tables you are using to enter data. In AX2012 you can use excel add in to import data. Google for excel add-ins to understand it, an example can be http://ax2012exceldataimport.blogspot.in/2012/01/dynamics-ax-2012-ledger.html?showComment=1371620600737
Thank you all !!! But how can I understand on which tables I need to enter the data ??
Krisheed
Hi Krisheed Immadi,
Please explain about your excel data.
For example: If you are having ledger transaction data in your excel sheet then please follow this URL http://ax2012exceldataimport.blogspot.in/2012/01/dynamics-ax-2012-ledger.html?showComment=1371620600737
Hari
You can make use of DIXF/DMF. First you need to identify the entity (for importing)
here is a list of supoorted entities, http://technet.microsoft.com/EN-US/library/dn507088.aspx
Yes, you can build the custom entities as well. http://technet.microsoft.com/EN-US/library/jj933277.aspx
Thank you all !!!
