Hi, I’m trying to create a file by setting up a report to a Generic Printer driver. It works. I get the file output but it’s truncated. Is there any way to change the font for this printer driver so that I can fit everything on my page? Thanks. Roelof.
Roelof, I have tried this in ealier versions and saving a report as a file using the Generic Printer driver has always truncated lines. I have never found a way around this. A little better solution would be trying to save the report as an HTML file. But that too has issues. Good Luck!
Hi James, Thanks for your reply. I hope someone can help me out with this. The HTML is not an option because the file needs to be used by a Pitney Bose system. Roelof.
