In Navision Financials 2.01 and earlier it was possible to create an empty object with the purpose of an automatic deleting of the object when imported into a database, by changing the default Action to Delete. How do I do this in NF 2.60? Best regards, Erik P. Ernst, webmaster Navision Online User Group
This is still possible Erik, just not using F3 as in older versions. Select the object type you want to create by choosing it in the left side of the object designer. Scroll to the bottom of the list, move one record down, so you have a blank line, use F2 to change the ObjectID and Name and you have your new object available, with zero length. soren@nielsen.dk
Hej Søren, Tak - thanks. Best regards, Erik P. Ernst, webmaster Navision Online User Group
