Creating a new Company
In 2.01 and up there is a function called setup checklist that will copy data into a new company that you have created. I have a client that is on 2.0 and he wants to create a new compnay and will only be using A/R my question is (Is there any type of function that will copy into the new company ?) Dave
My advice: Do it “manually”. There is a limited number of tables that should be included in the copying: Start two NF instances, step through the tables in Object Designer, Run and copy + paste the tables that seems to be what you need. Test run, and the program will protest if you have missed something. You might have it all done in an hour. Best regards Pelle
