In my form One grid is there.This grid contains Employee details.There is a TextBox above the grid.
Task is,
when i open the form the grid will show all the data.when i will enter a particular Employee id in textbox ,then the grid should show the employee details of enteredEmployee ID.
But Harish,suppose i want see the details of an employee having ID 20115,then according to you it is quit difficult to search this from the drop-down .so i want to enter this id and press enter,then the employee details of this id should display.
As of ur requirement u just go for an example .Account Payble–>Common Forms -->Purchase order details .
click for createing the new purchase order ,here Create purchase order form will open → in the vendor acoount filed -->u will get the dropdownlist here u can search like 8080,if that number is there it will come to first then u can select.otherewise it will not come .and otherwise u know the perticular account number like 1101 u directly enter in the box and click ok then the details will come.So in this field u just right ckick and select the setup u cam find the what table here using and then goto the perticular table and see the properies.then u can get that functionality.
