I created a new design for existing ExciseInvoice Report by duplicating the controller class (given new design name) and assigned it to a new button but it is still fetching the old design. Please help me
Ravi kumar
Ravi kumar
I hope you have taken menuitembutton for your report and you must have set the controller class to your new class.
Hi Lalit, thanks for your reply. No… I have created new menu item from the new controller class (which i duplicated from the original) in which i have give new design name.
Why do you need another controller? You can call the respective design in a single controller.
Look at \Classes\CustVendTransactionsController_CN\main
Hi Kranthi, I have checked the class which you have mentioned but I have created new design in the same report. My requirement is to create a report by the header Original copy, duplicate copy, triplicate copy…
For a calling different reports (or) different designs in the same report you can use same approach.
Here is another example: \Classes\SalesOrderEntryStatisticsController
