create vendor through X++
How to create vendor through X++ in Ax 2012
What is your AX version? Please always tag your AX version.
Have a look at \Data Dictionary\Tables\smmBusRelTable\Methods\relation2Vendor
Why are you not using DIXF?
Actually i want to create by job and including addresses,Contact information, financial dimensions, etc.
Still the same question is valid. If you don’t know how to write a job or DIXF stating point is the same.
Hi Kavya,
Create a Job:
static void createVendor(Args _args)
VendTable vendTable;
vendTable.AccountNum = ‘10001’;
vendTable.Name = ‘Vendor Name’;
vendTable.insert();
Add your required fields, whichever you would like to fill in related to vendors and execute this job.
