Dear all,
Is there any functionality to create partial Quantity from SQ to SO in Ax 2012 R2 Version
Thanks in advance
Dear all,
Thanks in advance
Moving your post to AX Forum for faster response.
Ok. Thanks for your kindly support, Amol.
Anyway, Does anyone has this experience regarding my issue.
Thanks in advance
seems you can’t change the quantity during the confirmation. May be to have the “proper quotation analysis”, the edit option is restricted. I suggest split the lines with needed quantities and confirm one line. i.e. if you have one line in the SQ with 10 quantity split it to 6 and 4 and then during the confirmation confirm the needed line. May be it gives you better tracking.
