I created a new partition in AX 2012 and while adding legal entity, it’s showing error “The number sequence for party records is not set”.
Have you completed the partition initialization checklist?
Yes
Then either let AX generate number sequences for you (Organization administration > Common > Number sequences > Number sequences, Generate) or set them up manually.
While trying to generate number sequence, showing “This application already has the required number sequence”
Then follow the second half of my suggestion - check if there is a number for party ID (Area: Address book, Reference: Party ID) and create it manually if it doesn’t.
