Create model from xml
Hi
I am trying to create model from a xml file but i am getting error . Does any one have done it before
PS C:\Program Files\Microsoft Dynamics AX\60\ManagementUtilities> axutil create @MyModel.xml
At line:1 char:15
  • axutil create @MyModel.xml
The splatting operator ‘@’ cannot be used to reference variables in an expression. ‘@MyModel’ can be used only as an argument to a command. To reference variables in an expression use ‘$MyModel’.
  • CategoryInfo : ParserError: (:slight_smile: , ParentContainsErrorRecordException
  • FullyQualifiedErrorId : SplattingNotPermitted
This command will work in the usual command prompt, but not in Powershell. In Powershell, use New-AXModel with -ManifestFile MyModel.xml.
Thanks Martin
