Hi everybody, i have a problem in creating a excel-file in Office-97. Name DataType Subtype Length xlsApp Automation ‘Microsoft Excel 8.0 Object Library’.Application xlsBook Automation ‘Microsoft Excel 8.0 Object Library’.Workbook xlsSheet Automation ‘Microsoft Excel 8.0 Object Library’.Worksheet xlsRange Automation ‘Microsoft Excel 8.0 Object Library’.Range CLEAR(xlsApp); CLEAR(xlsBook); CLEAR(xlsSheet); CREATE(xlsApp); xlsBook := xlsApp.Workbooks.Add(c:\test.xls); xlsSheet := xlsApp.ActiveSheet; xlsSheet.Name := ‘Tabelle1’; xlsSheet.Range(‘A1’).Value := ‘Test’; xlsBook.Save; xlsBook.Close(FALSE); CLEAR(xlsApp); The errormessage is like “test.xls could not be found. please check the path and filename”. But i only want to create it. I hope someone can give me a tip. thanks Ralf Beiten
Hi wrong forum [;)].
quote:
Try this: ... xlsBook := xlsApp.Workbooks.Add; xlsBook.SaveAs("YourName"); ...
bye André
Thanks André, it works.
Hey, the parameter in the Workbooks.Add should be the path to a existing Excel-Template File, so this is not what you want. Just use xlsApp.Workbooks.Add; without a parameter. To The save this workbook, and give it a Name us xlsApp.ActiveWorkbook.SaveAs. Fred
What’s cooking - Is Ralf the ghost of Hans Dieter or what?
NO HE ISN’T[:D][:D][:D][:I][?]
