Create EDT on Run Time
Hi everybody,
I wan tto create Extended data type on run time ,I write some code such as:
case AGC_ItemVariableType::ExtendedDataType :
FormStringControl = gr.addControl(FormControlType::String,‘RunTimeControl’)
EdtID variable have EDT Id exp for ItemId =260…e.x’
FormStringControl.extendedDataType(EdtID);
FormStringControl.label(‘Label’);
break;
when I click field which is created on run time Its look up don’t come ,have you any ıdea why ıtsnot coming?
Thanks all of,good working
I just repeated similar situation on AX 2009 and I could get the lookup, however I used ItemId as an EDT.
Maybe there is a problem with you “EdtID” type… Can you quick check if it works with “ItemId” as an EDT given for .extendedDataType() parameter.
Thanks for the post.
Hi guys, Im a newbie. Nice to join this forum.
watch movies online free
Hi,Thanks For reply I solved my problem ,It had some problem with lookup method.
Thanks again good working
HI Hulya,
Check this job, i am able to get the lookup…I took ItemID as edt in my exapmle…
static void RunTimeEDT(Args _args)
Form form;
FormRun formRun;
Args args;
FormBuildDesign formBuildDesign;
FormBuildStringControl formString;
FormStringControl c;
form = new Form();
formBuildDesign = form.addDesign(‘design’);
c= formBuildDesign.addControl(FormControlType::String,‘RunTimeControl’);
c.extendedDataType(extendedtypeNum(ItemId));
c.label(“ItemID”);
args = new Args();
args.object(form);
formRun = classFactory.formRunClass(args);
formRun.init();
formRun.run();
formRun.wait();
