I create one code unit for create automatic folder and copy data in subfolder. That codeunit work fine when i call that codeuint in page via button click but when i set same codeunit in job queue it give error like this
Microsoft Dynamics NAV
The automation variable has not been instantiated.
OK
Here i paste what i write in my code unit
This code for create folder. Move1 is automation variable (‘Microsoft Scripting Runtime’.FileSystemObject). Here R drive is shared drive.
MyPath := ‘’;
MyPath := ‘R:\NAVISION Report\QA\Daily\Shipment Monitoring’+FORMAT(Month);
CLEAR(Move1);
IF GUIALLOWED THEN
IF ISCLEAR(Move1) THEN
CREATE(Move1,FALSE,TRUE);
IF NOT Move1.FolderExists(MyPath) THEN
Move1.CreateFolder(MyPath);
This code for Copy Folder
MyPath := ‘’;
TextPath := ‘’;
MyPath := ‘D:\SummaryReport\QA Daily’;
TextPath := ‘R:\NAVISION Report\QA\Daily\Shipment Monitoring\June 15’+ FORMAT(Prefix);
//TextPath := ‘R:\NAVISION Report\QA\Daily\Shipment Monitoring’+FORMAT(Month)+’’+ FORMAT(Prefix);
CLEAR(Move1);
IF GUIALLOWED THEN
IF GUIALLOWED THEN
Move1.CopyFolder(MyPath,TextPath);
Please suggest .
Thank you.
