I am creating alert notification using below code in D365F&O through code on button click but its not inserting any record in EventInbox table not showing any notification in action center on running of change based alert batch job
EventNotification event = EventNotification::construct(EventNotificationSource::Batch);
CaseStatusSetup casestatus;
select casestatus where casestatus.CaseStatus == "Created";// Passing the item number for which we are going to show the alert
event.parmRecord(casestatus); // Name of the table
event.parmUserId(curuserid()); // User for which this alert has to be shown
event.parmDataSourceName("CaseStatusSetup"); //The form datasource
event.parmMenuFunction(new MenuFunction("CaseStatusSetup", MenuItemtype::Display));
event.parmSubject("Test"); //Subject of the alert
event.parmMessage("Test Event alert"); // Message of the alert
event.create(); // Alert creation
I tried to do the same using below code as well it is inserting record in EventInbox table but on running of change based alert batch job it not showing notification for specific user on Action Center.
EventInbox inbox;
inbox.initValue();
inbox.ShowPopup = NoYes::Yes;
inbox.Subject = "This is the Alert subject";
inbox.Message = "This is the Alert message";
inbox.AlertedFor = "This alert is just information no links are available";
inbox.SendEmail = false;
inbox.UserId = curUserId();
inbox.TypeId = classnum(EventTypeCUD);
inbox.AlertTableId = tablenum(CaseStatusSetup);
inbox.AlertFieldId = fieldnum(CaseStatusSetup, DocumentTYpe);
inbox.TypeTrigger = EventTypeTrigger::FieldChanged;
inbox.CompanyId = curext();
inbox.ParentTableId = tableNum(CaseStatusSetup);
inbox.InboxId = EventInbox::nextEventId();;
inbox.AlertCreatedDateTime = DateTimeUtil::getSystemDateTime();
//inbox.Visible = NoYes::Yes;
inbox.insert();
Am i missing something ?
