Create a Workflow for Purchase Order
I have to create a workflow for Purchase Order. The conditions for approving the workflow are set on the basis of the Net amount. As Purchase order workflow is not available in the standard system, i am not sure from where i have to begin. Help in this would be highly appreciated.
Purchase order workflow is available in AX 2012 (you need to activate the change management and configure the workflow).
If it is in AX 2009, this would require customization http://dynamicsuser.net/forums/t/59433.aspx
The version would be AX 2009. Thanks for the links.Very useful
