I need some help in learning how to add a new “item number” into the pull down menu in the Purchase Order Details. I have tried to add the new item in “inventory management” but it isn’t showing up. Does anyone have any other ideas?
I went to inventory management>setup>posting>purchase order tab>added it to the packing slip, consumption, and packing slip purchase. I am also wondering how do I add things to the “item code” column in the same screen? Because if I choose “table” rather than group or all I can see everything that shows up in the purhcase order “item number”.
You need to go to Inventory Management > Common Forms > Item details and create the item there. There will be some required fields such as Item Group, Dimension Group, Inventory Model Group.
