Create a group header
I need to create a group header with Dimension Code (Table 352) on the report 13302.
I want report 13302 order and group by Dimension Code
How can I do it?
Hi
Any idear for this???
luana - don’t be so impatient… 2 hours have only passed.
According to Obj.number R13302 is a n localisation object - but you shoud know it already, as, in contrary to majority of us, you’ve SEEN this report.
I haven’t, so I don’t know what is it about - but sorting, and from there grouping later, can be made only based on DataItem table KEY (index) only. That’s all I can suggest for you right now.
You can also take a look at FREESORT from the download section.
Perhaps that can help, it’s going to require some work.
http://dynamicsuser.net/media/p/152557.aspx
My report has only one DataItem = Customer.
I Need to group all my customer data by Default Dimension code field (Table 352).
Ex:
Default Dimension code X
cust1
cust2
cust3
Default Dimension code Y
cust10
cust12
cust4
For this case, I don’t know how to relate this 2 tables. They have in common the customer code. But from table 352 I only want Default Dimension code, from customer in my customer table filter.
Two options:
  1. If the dimension is a global dimension then you can group by this.
  2. If not, add in a dataitem for the default dimension and have the customer as a indented dataitem. Link the two and don’t forget to use the “PrintOnlyifDetail” property
Thanks Dave
The 2 option was ok.
But, with a groupheader for the field : Default Dimension code X, if there is no customer for a groupheader how can I avoid this section to be printed.
The groupheader is printed but there is no customer detail :frowning:
You don’t need a group header just a body for the default dimension and then the “PrintOnlyifDetail” property will fix your problem.
Hi Dave
I really need the groupheader, because in body section I will have problem, even with PrintOnlyifDetail" property check :frowning:
Thanks.
When your data item looks like:
Default Dimension
Customer (indented)
as advised by other members, you can take default dimension to be a header for Customer.
