Create a custom transform in AX 2012 to use in AIF
Currently AX supports XSLT and .NET assembly transform types, but my requirement is to create a new custom transforms within AX. My client doesnt want do to anything outside AX.
Is it possible to create some custom classes within AX and use in AIF transform type. Your input will help us proceeding further.
Thanks and Regards
Jismon Ittiachan
You can use pipelines, which are defined in X++. If you need a full-scale transformation, I would recommend using what’s already available. I think you would spend a lot of time doing something that probably won’t be better than the existing options.
If you decide to try it anyway, look at AifTransformProcessor class.
