Hello, i have following problem, on the Navision Server sometime the CPUmoni.exe is run, and need 100% CPU ?! and Navision is goning down For what i need the CPUmoni ??? Can i delete this file ??? ------------ Best regards Alejandro Schubert schubert@dolphinct.de
Just rename the file. Jack
Okay, but will navision works fine if he don t find this file ? And what do the cpumoni.exe ? I will first rename the file if i know that the file do ? But thanks a lot … ------------ Best regards Alejandro Schubert schubert@dolphinct.de
CPUMONI monitors clients on the Navision Server. It seems to taka 100% CPU but some people do not belive this is true. Maybe its reporting 100% usage when its not using it. If you rename it, the only bug is you lose option on monitoring wath users are “online”. We often rename it and its OK. Regards Gudumundur Petursson
Which monitoring you lose ? They Monitoring in Navision (Databae;Information;Session ???) I will try it, and trust in god ------------ Best regards Alejandro Schubert schubert@dolphinct.de
The only monitoring You lose if you rename or remove cpumoni.exe is the possibility to se the cpu usage in Client Monitor.
