After correcting the cache, I discovered that the cpu process on the server, were pretty unstable, and I found out that it were the cpumoni.exe residing in the folder of Navision Financial that caused the problem. The cpu were at 100% for a period of 2-4 minutes, and then falling below 5%, and then again going to 100% after a few minutes, and so on… I renamed the cpumoni.exe and the problem dissapeared. Does anyone have any suggestions to this manner, or any answers to what the cpumoni.exe were doing!! it seemed pretty strange… Regards from Blom
That’s the old cpumoni problem… the file is only needed for getting information about cpu usage and a few more usually-never-used features… so if you have problems about it’s cpu use, just rename it and don’t worry… Regards Alfonso Pertierra (Spain)apertierra@teleline.es
Thanks for confirming And thanks for the fast reply… Regards Blom
