Hi Everyone,
i’m new to Microsoft Dynamics AX 2012 R2. i’m facing an error “Coverage planning of item has been cancelled because receipt meeting the requirement cannot be found.” . this error occur when i start BOM process. inventory of used item in this process is ok but still it giving this error. please also see the screen shot of following error.
Please help me in this issue, looking forward for your help.
Regards
Faizan.
You will need to debug the code, this was logged on this forum a few years ago and that was my advice then, the user never returned the post, so any answer remains lost. When you find it please add the answer here!
Thanks for reply.
i will update you if i get solution for this problem.
Faizan
Hope this will work,
while Starting or Releasing the Production order UNMARKED the REFERENCE check .
This will allow you to post the order.
Sarfaraz
You have to delete all your dynamic planned order from planned order screen and try again, it will work.
Kiran Waghmare
