Couldn't able to close the Inventory in AX2009.
While Closing the Inventory, we received the following error in AX 2009. (This happens after GST (IND) Implementation).
Could anyone knows solution ?
Localization could have changed the parameter of that method and the caller might not have been updated accordingly.
Does the inventDimUpd_Financial class compiles properly? Compare the object in GLS\GLP to the highest layer and see if the code was properly merged…
Thank you :slight_smile: we have changed the parameter. it is working now.
