Could not load the selected type library.
Earlier today i’m adding some simple code to MakeCode 109 function in CU1. When i compiled it the program showed me that message and pointing to UserPortalApplServer function. This function have automation var that unable to identified.
My problem are the same as this guy http://www.mibuso.com/forum/viewtopic.php?t=19457&f=23
Is there a way to compile changes in CU1 without altering or deleting UserPortalApplServer function ?
hi,
there is an (old) automation dll missing.
this may help you: http://www.mibuso.com/forum/viewtopic.php?t=55126
so this dll is missing, the code in UserPortalApplServer won’t function anyway. check if that code is already used. to check that, simply comment out the code, remove the variable entry, which uses the dll. if it compiles and you can work normal, everything is ok.
regards
