I created a new label file with few labels and used them in one of the table fields. Every thing looks good until i close and reopen Ax Client. When i reopen the Client , the label text is missing instead shows only label ID.
Please help me with this…
You need to restart the AOS(service) by deleting the .ali(lable index file related to your label file).
hi karanthi, i did the same wht u said,
but still am pblm is solved…
it show only the label id
If you only deleted the file as mentioned above, try actually rebooting the AOS service.
As long as the labels are in the correct language, label issues are straight forward to solve.
We had discussed this issue many times here. Search is your friend.
