Is it possible to add surcharges to add surcharge percentages in costprice calculation, based on material and operation costs?
Please use Cost Groups → Inventory management/Setup/BOM/Cost groups for configure Profit percentage.
quote:
based on material
use for BOM lines Cost goups. In Items you define Cost group (Profit percentage) for each item.
quote:
operation costs?
in Routs you can use Costs Categories to define Cost groups.
Dirk Jan We are having an issue with this also. Valeri is right that the Cost Groups are needed to create a separate breakdown category for visibility but then the issue remains "How do I set up a surcharge on Material, fixed and/or variable? " The additional cost in the Item can be used but then it’ll always appear rolled up into the basic material cost. For Labor I tried a trick with secondary operations on non-existing virtual workcenters… For variable I just have to make sure I use an hourly rate that reflects the right labor overhead. For fixed I fiddle with a set up time and a setup rate that together give me the desired fixed labor overhead. (for a part number). It is a trick because these bogus operations will appear on production order overviews… still working through that. [B)]
