Costing Method
Hi experts
I’m testing the costs as a part of manufacturing module, I finished the setup and already tested with new items with standard cost, everything fine, but when I tried to implement this change against the current items I’m facing with the average costing method in the final product. Is there a way to roll up the item cost taking as a base the costs incurred in the route?
Best Regards
For the solution of the given problem, first you should get the knowledge regarding the average and actual cost of inventory. And after you can understand easily.
