I have imported worng costing method when i have make import of the items forom data migratin, I have choosen the FIFO method, but i want to chante to Average Method for all items. Exsit eany way to change without delting the data and rimport.
If you didn’t post anything for the item, you can use the replace function, or you can create a small batch that changes the costing method on the items you want. If you started to post some entries, then you cannot change anything…
The replace function is the standard one (Edit, Replace). If you don’t know how to create a batch, this means that it’s not you workl, so you must ask to a programmer [;)]
Why not delete the items and bring them back in again, it would surely have been quicker than this post - unless you wanted to learn programming solutions?
