HI
What is the use of the COST IS ADJUSTED field in Item card.
How it is useful .
Please try to explain with an example.
Thanks and regards
HI
How it is useful .
Thanks and regards
If that field is check than adjust cost batch won’t run for this item.
I receive an Item for 10.00 - Cost Adjusted is No
I match the invoice for 12.00 - Cost Adjusted is No
I run the Adjust Cost Item Entry Routine - Cost Adjusted is Yes
Helps you identify very easily what has the final cost and what does not!
