cost category identical with account number
Hi
cost category identical with account number is not enabled in CostAccounting module ->setup->parameters- cost category group…
this is a check box is not enable how can i Enable this option…
Thanks in advance
Sunil kumar
This check box will be enabled when there are no Cost Categories defined.
If any cost categories are defined - this check box will be automatically disabled.
if you want his to be enabled delete all the cost Categories.(this the logic behind it)
