Corrupted file?
[V] I try to expand my database… the expansion was interrupted. So when I try to open my database navison tells me that The size of the databse recored record on the databse itself is different woth the size of the file in your operating system… Did I lost every thing Thank you for your help [}:)][:(][:(!]
I belive you have lost evrything. Valentin Gvozdev Andel Jewelry Inc.
We had a similar problem with a client and I think that Navision headquarters in every country has a way of fixing a crashed DB. /Sven
Unfortunately when expanding a database, all bets are off when it comes to recovery. The version principle does not work. You can try to fix the record lengths, and then create a backup and start again, but I have never been able to recover a database that crashed during expansion. Best bet is to read the instructions. I.e. tha manuals state very clearly to create a backup BEFORE expanding the database. Mind you “read the instructions” and “Create a Backup” all in one sentance is probably a little more than we can normally expect in this industry [;->] sorry.
This happened to us a few months ago and Navision US was able to recover it. You should ask your NSC to help you before you assume the database is lost.
quote:
Hi! I had a similar expiriance. Call your NSC or NTR. NTR have a tool to fix corupted databese file. Regards Bostjan
