using ver3 SP2,we get different values for stock figs, depending on which standard report is used In particular the fields “known” and “floating” value" & "physical value are different The ledger accounts dont reflect what the reports show There appears to be no documentation on what each field is supposed t represent and how its calculated
Hi Jeff, If I remember correctly, there were bugs (mainly calculation errors) in various reports in Axpata ver 3.0 SP2 Stock management module. These bugs have been corrected in Axapta 3.0 SP3. In case if you don’t want to upgrade to SP3, you can download and install hot fix. For the hot fix details please log into Partnerguide or if you are a customer, please contact your reseller. Kind regards, Harish Mohanbabu
