Hi, Is there a standard functionality where an item gets created in a core company and it can be subsequently be distributed to multiple companies(ceu,cee,cet) with same settings.
eg. company 000 users can create the item and distribute the same item to different companies
but users of companies other then the 000 cannot create the item
Note: If the companies are not listed in the core companies distribution lists they are free to do anything in that particular companies.eg. company xyz can create an item whereas company ceu cannot create it.
Can anyone crack this problem or has worked on similar situations like this
Please let me know.
This is not standard functionality, however you can achieve this by virtualizing the item table (which I do not recomend) and then give apropiate rights to certatin user groups for creating items. The task of virtualizing is not that easy, specialy with the items table.
If you could use Dynamics Ax 2012 then you could certainly achieve this, otherwise you need a customization and not a “crack”
