Greetings, I have two forms the first is caller for a second one using a menuitembutton , but i have to retrieve selected data from a called form to the first one after closing it .
help me if you know how , appreciated your help ,many thanks.
If you need data from second form to first form, Then you can override the “close ok” or “can close” method of the form and write your logic in that and you can do the modifications in first form.
First overrride the canClose method of the form then declare the class and instansiate it and you can pass the selected record recid in to your class from that.
Boolean return type will only specify that its true or false(for closing mechanism).
