Copy roles from one user to another
Hello,
I have to copy roles from one user to the other (all windows logins) and wonder if there is a better way as re-entering each role.
Your help is very much appreciated
Thanks, Frank
I think you can copy and paste the whole list. It’s been a while so I forget. Past that, if you have development access it is pretty quick coding.
You could also look into the EasySecurity add-on. I can’t remember if the free version does what you need.
Yes You can copy & paste the role from one user to another.
How would you paste multiple roles?
Thanks, Frank
Just select the entire list. You can highlight them manually or do Ctrl+A to select all. Ctrl+C to copy, Ctrl+V to paste.
Many thanks. Well, often we don’t consider the most obvious soluiton.
