Hello, im trying to make out of 2 tables 1 and then print the information on a report. And this worked only that the amount is ever 0. So i looked in the table from where i copy my records the properties of the amount field and found out there is no value stored, and theres some sum() stuff in the Calcforumla.
So after a search i found out, that i have to make a calcfields before i copy the fields. But the amount field on the report is still zero.
filling works like:
IF Verkaufskopf.FINDSET THEN REPEAT
Verkaufskopf.CALCFIELDS(Betrag, “Betrag mit MWSt”);
tmpVerkKopf := Verkaufskopf;
UNTIL Verkaufskopf.NEXT = 0;
nav 2009
In which trigger have you written this?
where did you add the field in sections?
Claissc/RTC?
In the OnAfterGetRecord, and like i said the filling works well just not the amount field…
In the Body Section i have a field with sourceExpression tmpVerkKopf.Amount. Fields like tmpVerkKopf.Number are working.
Is this code under Verkaufskopf Dataitem OnAfterGetrecord trigger?
Does the last record in Verkaufskopf table has Amount <> 0?
DataItems:
-sellers/buyers | sellersbuyers
- -Integer | Offerten
In the sellers DataItem OnAfterGetRecord i make a filter on the table SalesHeader(record var) to look only for current seller and many other filters… then i make a loop throug the SalesHeader(record var) like this:
IF SalesHeader.FINDSET THEN REPEAT
SalesHeader.CALCFIELDS(Amount, “Amount mit MWSt”);
tmpVerkKopf := SalesHeader;
tmpVerkKopf.INSERT;
In the Offerten DataItem I use this to print the Information form the TempTable I have the
Properties: DataItemTableView: SORTING(Number) WHERE(Number=FILTER(1…))
OnAfterGetRecord:
IF Number = 1 THEN
tmpVerkKopf.FINDFIRST
ELSE IF tmpVerkKopf.NEXT = 0 THEN
CurrReport.BREAK;
Write below code in Integer dataitem at the end of above code…
tmpVerkKopf.CALCFIELDS(Amount, “Amount mit MWSt”);
Yaaayy this worked [:D] thanks! but can you explain me why, i have to make a calcfields on the temporary table?
No need to write this code unless you want to use sales header amount field some where…
As you are trying to show the values from Temp table, you need to calculate flowfield of temp table only.
