Copy data
Hi! Is it possible to copy settings from one database to another? Janis. J.K.jr.
Yes, under General Ledger, select setup, then setup checklist, under functions is copy data.
setup - copy data copies only data between different companies of the same database. Except for Dataports I don’t know of any “legal” method to copy settings between different DB’s. ------- With best regards from Switzerland Marcus Fabian
If the databases have compatible objects then you can backup a company in one database for restore into another. Its is possible to cut & paste certain records from tables, and paste into others. I would suggest using dataports as Marcus has suggested. You may want to export to Excel first if you need to manuipulate the data or columns.
thanks. Janis. J.K.jr.
