converting to dll file
hi,
i want to convert an axapta class as a DLL file
can any one help me about how it is going to create a class as dll file
thanks & regards
saeed
you cannot do it. You can only use ABC – Axapta Business Connector (see developer’s documentation)
I think this can be done by implementing exactly the same code from the class’s methods into the dll’s methods. As AxCoder mentioned, the only difference will be that the references to any Axapta objects will have to be implemented by using ABC (they cannot be referenced directly because they are not recognized outside Axapta).
