i have a NAV 4.0 SP1 database, how is the best way to convert it to NAV 4.0 SP3
There are 2 ways to do it
2)Objects and Functionality Upgradation (which you need to contact Partner/Senior in your office)
if i press OK, this will damage my data??
No…
Hi, and make a backup first just to be safe!
Well, but you will not able to open the DB with 4.0 SP1 again.
what the advantage and the disadvantage when using this feature (Converting the database) ??
i want to know if this affect to my data?
This feature will convert only Excutable and this will not affect your data
But If you do this you will not able to open the database in previous version you have i.e 4.0 Sp1
Better Solution to upgrade :-
Object & Functionality up gradation using Developer Tool Kit.
