convert decimal into text
hi,
I’m designing the commercial reports (quote, orders, invoice etc) in dynamics nav 4.0 and I want to convert decimal (amount) into text. exp: 110 = one hundred and ten.
someone tell me to use the function FormatNoText. can U tell me how use this function?
thanks
In the NA localization this is done in the “Check Translation Management” report, which has functions to translate numbers into text in the 4 different languages that are (or rather ‘were’) included in the NA localization. You can run the report and it will show a number of different examples of numbers and dates. How it works exactly you’ll have to figure out yourself by debugging it, it’s been a long time since I’ve looked at that :).
http://dynamicsuser.net/forums/p/3010/125720.aspx#125720
