Hi guys i need a help in this one.
Table1.SETRANGE(ID1, ID2);
IF Table1.FIND(’-’) THEN
Table2.SETRANGE(TID1 , Table1.ID1);
Now the problem is in converting the value from code to integer,
Table1.ID1 value is code.
Table2.TID1 value is in integer
I am getting the type conversion error.
How to fix this and get the setrange to work please help.
Thanks.
Try
IF NOT EVALUATE(Table1.ID1, Table2.TID1) THEN
Table2.TID1 := 0; // Table2.TID1 is not an integer value
Thanks Erik,
But i want to filter the record thats why i am using the setrange to filter the records.
I dont want to check if its integer value or not. I want to match the integer field with the code field data type how can i do this.
Thanks.
Try
IF Table1.FINDFIRST THEN BEGIN
EVALUATE(VarInteger,Table1.ID1);
Table2.SETRANGE(TID1 , VarInteger);
END;
Where VarInteger is of type Integer…
Thanks mohana it is working great.
