conversion to multi langauge
Hi I need to convert all the captions on the forms to korean - verison 3.10. i think some of you guyz might have done this before and if you can share your thoughts, i can have a quick start. Thank you regards MK
MK, if you just convert the form caption only (as you said), it may not be difficult. But if you talked about the message show in the forms, it may be completely different. Some functions in the form may call reports(for data processing) as well, it means you may need to convert the reports. Also, have you considered the tool bar and codeunits in the form? So, think about what you are going to convert really. Rich
MK, Also some wording are taken from the tables. Then how can you just convert the form’s caption? Rich
MK, the localization workbench will help you a lot on that. Also you’ll need to go to the tables and set the CAPTIONML property to both, english and korean. The hardest thing is that you’ll need changing the codepage when inserting the korean descriptions. Regards,
Hi Guyz Thanx for your ideas. Infact while i was goin thru the Localization workbench i did come across the need to convert the error,confirm messages etc to be converted into korean. hope to see some more inputs… Thanx MK
