Control permission on ledger entries based on user setup - NAV 2016
Hi everyone,
I have the following request from a customer:
Based on a boolean on user setup, the user should/should not be able to “see” Vendor ledger entries:
for example: when the boolean is off:
  • The user gets nothing when he tries to access the vendor ledger entries from vendor card.
  • The Vendor ledger entry list shows empty.
Is this achievable in NAV 2016?
Hello,
You can set the visible property in repeat group with a variable which is either true or false.
best regards,
kauffmann.nl/…/
Kaufmann has a good article about this.
best regards,
Probably a better way is to use the AccessByPermission property (msdn.microsoft.com/…/accessbypermission-property)..)
In combination with proper permission sets that will do exactly what you are asking for.
Nice!
